Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,753
Wow. Thank you so much and I will need this...when I get a new solenoid. I should have tested it first especially with such a banged up box. I put 12 Volts to it and no click. I further tested for continuity at the load terminals and found none. So returning this one to Amazon and waiting for a replacement.
Newbie question coming. Does the solenoid have to be grounded for this application? It appears that you have attached the grounding plate to the neutral side of the battery.
I was wondering why he used only one screw terminal. Thought circuit was completed to one of the heavy terminals.
No, that couldn't be, both end up at +12V.
Could well be the coil is from one screw terminal to bracket.
"returning"
If not yet returned, try, try again!
