Trick question?Does a 5/16 ring terminal or lug fit on an m8 stud?
Trick question?
5/16 = 7.9375 mm
Thanks.8 mm > 7.9 mm
8mm > 5/16"
a 8mm rod will NOT fit in a 7.9 mm hole
last time I checked
Lolz8 mm > 7.9 mm
8mm > 5/16"
last time I checked
There is some tolerance. They may have changed the rules since the last time I used 5/16 ring terminals on M8 bolts.Seems I stupid today.
Yeah i work on 2 stroke engines that have 8 mm 1.25 threaded studs with the aluminum head gasket holes at ~ 5/16 there is all kinds of slop.There is some tolerance. They may have changed the rules since the last time I used 5/16 ring terminals on M8 bolts.
I have enough trouble with his ever changing profile picture, there is no way I am going to figure out what frame of mind each of his posts are coming from.Pretty sure smoothJoey was employing veiled sarcasm.
Snip the O ring into a C ring, good to go!
Me tooI have enough trouble with his ever changing profile picture, there is no way I am going to figure out what frame of mind each of his posts are coming from.
So you are saying I'm not stupid then, just crazy?Me too
Reminds me of the line in that Waylon Jennings song, "I have always been crazy, but it keeps me from going insane."So you are saying I'm not stupid then, just crazy?
