exactly, but product of this spec. is yet on the market. i know the road map.Welp, here's something that backs Peter up: Tesla may buy CATL'S Lithium Iron Phosphate Cobalt-Free Cells
@peter.w are you talking about selling this LifePO technology?
I agree with @Ryang.
My suggestion is to post prices for your batteries including shipping with the option of sea or air. Or set up a website for the "little" guys to order cells from. Surely you could be competitive with the other distributors considering the volume of cells you have. If you could throw in buss bars and bolts that would be a plus depending on the cost of the batteries. You could also offer smaller prebuilt packs with a built in BMS. In addition having some after sale support from you would be very valuable. I think everyone understands there will be a shipping cost. Just throwing out some suggestions. If you don't want to deal with it or can't for some reason I fully understand.
I appreciate your safety concerns. Thank you.
thanks for the suggestion. first i will make some sample and post it here, pls leave me sometime.Thanks. and to answer your previous logistics thoughts. Most here accept there is a shipping cost and build it into their calculations.
Quality and value is the foremost priority for many.
i think i will first provide something in this way, since my battery requires laser welding. within these days i will go to my factory and discuss with my team. it won't be difficult.
i will make 12V100Ah and 12V280Ah first, what do you say? i will post it here.
I like that idea but you might want to think about offering 24 volt as well. If the 12's can be connected in series that would work. Many here like to "know" their batteries so adding a smart BMS would be beneficial. Can studs be laser welded to your batteries for diy? Looking forward to what you come up with. No rush. Thank you for your considerations.
replied your email,bro.
What we're looking for in a BMS is features like active balancing, settings adjustments using a bluetooth iPhone and Android app, like adjustable low temperature charging disconnect, high amp draw disconnect, adjustable battery capacity or voltage ranges, and also fairly higher amp draw capabilities, 120A, 150A or even 200A without using a relay, SSR.
Hi Fish Freak,
Will doesn't believe active balancing is necessary.
I know the batteries should have a BMS and some use their LiFePO4 batteries without them. A properly matched set of cells might never need balancing. Would I use a pack without a BMS? Hell no. I want the extra safety a BMS provides. I thank you for your post as it explains what we are looking for. However I also very much like Peters build examples as this would take a lot of the hassle out of a diy project. Also considering Peters cells are grade A, and I am sure properly matched, I believe it would be rare for a cell to go bad unless of course the pack is abused.
my cells may never reach the 3.65v needed for a top balancing bms to go to work
I have no idea what a top balancing bms is.
The Chargery bms is passive and can be set up to passively balance during any or all of the following:
Charging
Discharging
Storage
You short cycle use has no implications since the passive balance can be working all the time.
Hope that helps.
I was not planning on going Chargery, probably just use the popular and less expensive DGJBD because I need many of them, which supposedly doesn't start balancing until the cells reach top charge voltage. Are those little add-on balancers actually considered passive? Lol, the Ali post of course says 'active'...
@Fish Freak @Gazoo @JoeHam @NEWYORKHILLBILLY Hi Bros, what an intensive discussion have been raised. I made some wrap-up in order to move forward correctly.
1. a stud welding on top of positive and negative port: let me check if i can come up with better idea to give more option for DIYer. but first i will make up a outcase so that it looks like a produt .
2. BMS:
i am pretty impressed that you think through the questions debated in industry for many years. Active balancing or Passive balancing, it is question. To make it simple, i firstly make a rough conclusion that for battery configuration in such scale (a few kWh even a few tens kWh), Passive balancing is more than enough unless specific requirements are needed. Active balancing will increase the complexity thus decrease the reliability of the overall system, that is why it would be very careful when introducing active balancing. You may look into Tesla's BMS control stradegy, which i take as the best untill now, since it manage a few thoundsands 18650 entirely. The complex BMS hardware and algorithm invloved will be a huge cost for any individuals like DIYer.
back to what we confront now, the BMS used mostly here is so-called protecting board of Li-ion battery, mostly manufacutured by some electrical factory in China. The advantage is they are cheap and easy to get. The BMS used in ESS will be more comlicated than this, but the cost is higher. By drawing an analogy, protecting board is like i3 CPU and BMS is more like i7 or i9 CPU depending on practical application. What i am aiming at, is to find a cost-effective protecting board for the current applicaiton. Pls share with me what you have used with links and suggest what you think is good. e.g. pls put the link of Chargery product for me to evaluate. BMS will also determine the safety level of your system, so be very careful
Cheers
Hi Peter,
Thanks for your reply.
The link to Chargery is : http://www.chargery.com/ There is a lot of discussion about Chargery on the forum.
Anyway great discussion here:
Will blasts Chargery
So here it is Will dislikes the Chargery BMS. I don't disagree it's a bit quirky but. He proves how it is fully customizable even if it isn't for him. He does agree that once set up it works fine. I hope everyone who considers buying a Chargery watches this video. I am still a huge fan but...diysolarforum.com
I just noticed they are offering battery chargers as well as BMS. I don't know anything about Chargery except the BMS requires external relays. If I read correctly users have been complaining about the relays getting hot and high power consumption to the relay coil. Some forum members have found alternative relays that work well with the BMS and there are a couple of users on the forum experimenting with solid state relays. However Chargery has made improvements and from what I can tell users are happy with their BMS. But it is a complicated set up. Always looking forward to your ideas. Thank you.
Chargery locates just byside, i may drop by on site
Cheers
