I read this topic once here in the forum ….but forgot the answer…
Let’s assume the panels are producing 3000 watts , and there is no load at all on the system.
In this case all the power should be going to the battery’s to be stored If there is room In the bank.
For some reason I decide to turn on the multi+ and a load that requires 1500 watts and the inverter starts to invert DC power to AC power and supplys that load.
The panels are still producing 3000 watts and the single load is drawing 1500 watts and is doing its thing.. …( For this example ignore the small power draw of the Victron).
Question: Is the 1500 watts ( of the 3000 supplied ) being used for AC power ,coming from the batteries AFTER it is stored in the batteries and then drawn and converted by the multi + to AC as needed by the load …?
OR is the 1500w ( of the 3000 supplied ) being supplied to the multi+ and going to the load First , and the other 1500 is being stored in the batteries… ?
Furthermore , If I turned on two loads of 1500 watts each would it all go to the load and none to the batteries OR does all goes to the batteries FIRST and then be pulled back out and sent to the inverter and then to the loads.
There is a reason for this question ,but I’m trying not to complicate things …
Thx, J
Thx, J
