Drafting a VanLife system - thoughts on this system? Specific questions under the diagram
clammchops
Yes it will work for four in a 2s2p setup. It does have a max of 700watts @12v (everything above that will just be clipped). But the big advantage is all the additional watts when not in ideal conditions. I only noticed the clipping once on my rig (four flat -mounted 200w panels).
Good to know. To maximize our 800W (if we got 4), we'd probably want to upgrade the MPPT so it's not clipped
Rocketman
My understanding…
Non-isolated are for MotorHome’s and vans. Where both batteries negative wire are connected to the same frame.
Isolated are for trucks and trailers - where there is not a solid negative connection or other areas where the systems are separate.
