Heh... try to proofread your posts before posting thhread
3 years ago, 8 neighbors of mine followed my lead and all got Sol-Ark 12K. I am happy with my solar system it works fine no problems.
I am amazed with the sol-ark 12K from a neighbor that pulls around 100 KWh every day which is around 100% or more based on the specs (we live in Arizona).
Another system is a dual 12K system with one indoors and one outdoors inverter, that system was working OK but a year ago I realized the installer left it on limit to load mode.
I changed the inverter to limited to home mode, the system works OK for about 20 minutes after that if the home load is low it works OK but when the load is more than 1 KW then it sends or receives power from the Grid sometimes up to 10KW.
I have been calling Sol-Ark support in the last 6 months about once a month with no answer to this problem, their support used to be great before, now they leave a lot to be desired also some of the support people nowadays they don’t even know the specs on the inverter. I lost faith in the Sol-Ark support after about 6 tries on this problem.
I was wandering if any of you run on this issue and have a fix.
So far, the software on both inverters are updated.
I did a factory reset.
Replaced both CTs and new Cat8 cable, about 50’ long. I checked the old CTs with a scope and they work fine.
Tried all wiring combination with CTs, system still fails on the Limited to home mode.
