DIYrich
Solar Wizard
Just for kicks, put the CT's by the Sol-ark on the grid line to the main panel. See if limit to home works correctly (should be like limit to load).
If it doesn't work, gives you more ammo to Sol-ark that a circuit might not be working. If it does work, then it might be a CT wire length problem.
Also, try swapping which Sol-ark is the master (CT goes on the master).
