kburndred
kim@burndred.com
If you're experiencing random restarts and power outages from your parallel inverter setup I have 2 things that completely solved the issue for my setup.
1. Ensure that the parallel cables (15 pin) and the power sharing cables (red/black twisted pair) are NOT in your wireway/cableway!! These communication cables are highly sensitive to noise from AC induction etc. As a side not I will be replacing the red/black twisted pair with a shielded cable and contacting SS to advise them to ship shielded cables with their inverters in the future.
2. If you're using Solar Assistant, plug in monitoring cables to both inverters. Yes 2 cables!! Both these cables plug in to your Raspberry Pi USB ports. This creates an "inverter cluster" in Solar Assistant. The reason for this is so that the 2nd inverter data is no longer read via the parallel connection, instead each inverter is read directly. The result is that there is no monitoring traffic on the parallel communication cables. This removal of extra traffic stabalizes the inverters. In addition you will see all the data for both inverters, including inverter temperature etc that is not shown when data is read via the parallel connection.
These 2 changes have made my system ROCK SOLID. Please let me know if you get the same result.
