EG4 6000XP Released, ordered. Let's Go!
Is there a BMS that works with diy batteries and the 6000XP? I have a pallet of batteries for diy packs I will be building and have not bought a BMS yet. I have 3 6000XP's ordered I am going to be using the batteries with.
Not sure, hopefully someone else can help with that. I have the JBD from overkill solar.
This might be an option
What do you think of this?
I know you can have close loop with External BMS like this one its just getting the right software or protocol selected and figured out. Their are a handful of people here on the forum that i know of who are doing this.
Sorry if this is a repeat question, but can someone explain this option to me? Especially DC source mode.
PV Input Mode: This allows the user to select the PV source for the Inverter. This can be:
0: DC source mode, 3: Two MPPT connects to same string, or 4: Two MPPT connects to
different string.
I've been waiting for this as a "sweet spot" for my cabin build. The 18kpv is sexy but overkill for my needs (though I had my finger on the trigger). Lux has demonstrated their ability to build a high-quality product...hoping this is no exception to that rule.
I will be sure to document my experience.
I have a question, this unit is nice, but do I have to actually use server rack or the 14K battery? or can I buy the 12v 100a lithiums on sale at Amazon to use with it? I understand they wont have the communication and smart features, but I cant afford the crazy high tech stuffs... I just need to expand as I can afford to. Sig Solar sells these guys as refurbs, too, so I can save a little there
You would have to series four of the 12V together to get to the 48V nominal battery this inverter requires. Which then brings up potential issues with balancing between those four (or more) batteries. But can be much cheaper than an off the shelf rack mount battery.
4 x 12V batteries in series will work, kind of, with the 6000XP. Two problems.
1) Balance issues as Brucey mentioned.
2) The discharge rate of the 100Ah batteries would exceed 1C if the inverter had a 5,000W or more load on it.
or, go for broke and get 48v... man. I wish I made more money. saving currently. (currently..lol punny)
I try like hell to not use anything that uses more than 1500W at any given moment. We are pretty primitive out there. No large appliances. But, I like the idea of having the capacity if I need to.
I thought I'd add my own quick install story to this thread.
I purchased a 6000xp through Current Connected along with one of their 5 unit SOK 48 volt rackmount kits, a pair of chargeverters and the bus bars and additional cables needed to wire everything together.
I've installed all of the above at an off grid cottage in Michigan. Over two visits the inverter has performed just as I'd hoped. It comfortably handles the surge from a 1 HP well pump and runs all my remaining house loads without issues. I see modest transient pulses of my LED lights when turning on high draw items like vacuum cleaners and a microwave but that's about it.
The inverter began communicating with the SOK battery bank right away, without any further configuration needed. (SOK seems to provide the same over the wire RS485 protocol as the EG4 batter line.)
The chargeverters are doing exactly what they are advertised to do. Together I've measured them delivering the full 10 kW of charge current, allowing me to run an existing pad mounted backup generator at a very healthy percentage of its capacity and minimize the amount of time I'm making noise in an otherwise quiet environment.
Current Connected were great communicators, particularly around the challenges associated with delivering freight to a more remote location and were responsive when I had a few concerns during the install.
I'm looking forward to adding panels sometime this spring.
different string.
Did you ever get a reply? I have a single PV string and wondering if it needs to be supplying both MPPTs. I believe doing so would keep the voltage constant but divide the total Amps between PV1 and PV2…
The MPPT's can parallel an array at the inputs or have two separate arrays for each MPPT.
I am planning to use the EG4 6000XP with Longi 550W (49v open circuit) Panels
I see that the EG4 6000XP has 2 sets of PV inputs, I assume that this is for the 2 internal mppts.
Can I run two strings of 8 panels (4,400 W) Max Open circuit voltage will be around 440V for each string?
Does the EG4 6000XP max open circuit voltage of 480v mean I can run 2 PV strings each with a max open circuit voltage of 480v, or does each string need to be a max of 240v?
480V per string.
One string to both MPPT's?
No way. I think he's trying to say two strings can be paralleled at the inverter to one MPPT. there are 4 connections ++-- for each MPPT. Not looking at the book. But I wouldn't do that, unless you needed to from a capacity standpoint.
But the actual usable voltage range for PV is 120V to 385V
So I would see 2x8 just about perfect. 8 panel Voc would be ~400 well under the 480max, puts operational voltage right at the 320 number at about 13-14A per string under the 17A number. Doubt you could configure something much more optimal without using a bunch of much smaller panels combined more creatively.
Each MPPT is rated for up to 480VDC. 8 panels in series would work to each MPPT with the open circuit voltage around 440v. However, depending on low temperatures in your area, I would make sure to account for the temperature coefficient depending on the record 100-year lows. This calculator may be helpful.
@EG4TechSolutionsTeam So just to be super clear, I am perfectly fine to do this with my array (see below), assuming the panel current, VOC and all are within the spec's that have been laid out in the manual and the discussion above? Two arrays, combined into one homerun to all in one inverter. At the 6000xp PV inputs I jumper PV-1+ to PV-2+ and PV-1- to PV-2- to parallel both MPPTs to one string. Additionally, change setting 2 in the inverter menu to "P" for same string input for 2 MPPTs.
No. One or more parallel strings to each MPPT. You can't have a string shared between two mppt controllers.
Edited to add: I was mistaken there is a parallel mode, please disregard.
