That's not how the unit is advertised, nor is it set up that way. This unit was set up with the Ct's pointed towards the inverter to keep from sending power to the grid along with the Grid disable set to enable.(stupid) Everything runs through a critical load panel on the AC output. Went through the settings with tech support for hours, several times to try and get the unit to not stay in grid mode. The inverter, if operating correctly, is not a good setup for any off grid or grid assist system. The dual outputs is unnecessary if the inverter was programed from the factory correctly. It seems like an intentionally crippled machine with a just plain bizarre setup.
