Makes one wonder how many other people have had this happen and didn't make the connection.
I've had mine running since early June. I've had myriad issues, EG4/SS does not pay me or anything. I can also be the biggest pr*ck on the planet if I've been mis-treated by a vendor. SS phone support has been abysmal for me in the past. Though seems to have improved dramatically over the last few months.
I've never recorded any kind of a significant voltage spike from my inverters. I've been monitoring Volts, Amps, Frequency, and KWH on my main panel feed since 6 months before the solar was installed. ... Thus I have a pre-inverter baseline as well. In the summer, right after they were installed, my units were cycling on and off switching at least twice every day, as batteries depleted, and recharged. I was also fiddling with it not infrequently putting the units in and out of standby. I had a number of phase match issues from running a transfer switch and not using the grid tie lugs, some of those switches created some nasty noise from the HVAC until I came up with a work-around to stay in-phase with the grid. I even had a firmware bug associated with the batteries that caused the inverter to cycle on and off repeatedly every few seconds (still testing to see if this is resolved, and get a better handle on it, it's an esoteric set of events). The bulk of the rest of the issues I've had have been fixed or almost completely mitigated by firmware upgrades.
Thus I would struggle believing that a properly installed inverter would create a spike capable of frying a circuit board in an appliance simply because it was cycling. The low voltage part of the circuit designs in major appliances, HVACS, Microwaves, Stoves, Washer/Dryer's are generally extremely tolerant and behind some step-down transformer/circuit. I've had my house hit with a direct lightning strike in the past, that actually took out an incandescent light bulb, that never fried any major appliance electronics in an all electric home. It did make the wifi radio the antenna was attached to explode, the antenna fragments were all over the neighborhood, it took out the router behind it and fried a port on the switch, and pretty much scared the pee out of everyone in the house, the HVAC was running, the TV was on some breakers popped, so I do see the possibility. I am just struggling with this inverter doing it because the way it's engineered there is a delay while it verifies it's ouput is stable before it engages the relays. In fact, the output is generally more stable from my inverters than from the grid.
So I've seen a number of people report these kinds of incidents with "inverters", not just the EG4, but if you are having these kinds of problems, I'd put a sensor on your feed lines, and re-check all of your wiring and grounding. Frankly the worst spikes I've seen (besides lighning strikes) are from the power company after a power outage. Got nuthin of note from the inverters in my logs. YMMV.
