So I guess I don't understand this.
EG4 6500ex in phase 180*
3 Lifepower4 batteries.
I disconnected and individually charged each battery with the EG4 charger to top them off. BMS_test was saying 2 of them were around 99.4%. After charging all were 100% but when I restarted everything, the inverters immediately tried charging them.
Looking in the menu, I see bulk is 58.4 and float was also 58.4.
I'm using EG4/USE for #5 and can't change them. I have the latest firmware in everything.
I did try putting both inverters in USE and setting the float to 54v and it seemed to help it to stop charging finally, but is this safe to run this way? I left bulk at 58.4 volts so it can equalize the cells at full charge and this was also the setting in the inverter and also the same voltage the battery charger uses.
Help!
Thank you
Help!
Thank you
