hi,
I currently have my batteries set to 58v for High Battery Cut Out. I am on closed loop with Schneider xw pro and eg4. Should this be 58.4v? I don't see it mentioned in this doc:
Got this alarm today:
Cause: Battery voltage is (BattV), which is approaching the High Battery Cut Out level of (HBCO). Solution: Check battery cables. Check for the correct battery voltage at the inverter's DC input terminals. Make sure the DC source is regulated below the high battery cut out or increase the High Batt Cut Out setting.
Cause: Battery voltage is (BattV), which has exceeded the High Battery Cut Out level of (HBCO).Solution: The fault can occur when batteries are disconnected at theDC breaker while the inverter/charger is operating.Solution: Clear the fault and attempt restart. Make surebattery voltage is below 29 VDC (24 V system) or 58 VDC( 48 V system) at the inverter/charger DC input terminals.Check all other charging source outputs and battery cables.Make sure that batteries are connected or that your DCsource is regulated below your high battery cut out orincrease your Hi Batt Cut Out setting.
Other settings:
