I have 2 6000xp and a 14.2k power pro battery running amazing after a few adjustments I have no PV and my plan was to charge off a 30amp 240v grid tied circuit running to a bardo house. Just to find out I could not charge from grid and run heavy loads without tripping main breaker. So I decided to buy the EG4 Chargeverter to charge batteries, this worked out beautifully for charging and running loads without any issues. Now the problem is it will not stop charging batteries as long as there is power running to chargeverter. I found a couple treads mentioning a work around with a 240v AC contactor with 24v coil wired to a 24v transformer, however there is no details on how to wire this to the EG4 Chargeverters dry contacts to stop and start the charging. The 6000xp’s are communicating with the battery so my plan was to just set parameters to voltage instead of SOC. Any one able to post wiring details would be very helpful. Thanks for your time on this.
