Vigo
Targeted ads make me feel better because it means im being data-mined the most efficiently, and who doesn't love efficiency?!
I hear that, nothing like comparing power hitters like Lou Gehrig and Mickey Mantle to Aaron Judge and Giancarlo Stanton with your buddies, then getting a nice add selling antique Yankees memorabilia pop up in your Facebook feed. Especially when you are from Texas and never even so much as googled the Yankees. (This happened last night)Targeted ads make me feel better because it means im being data-mined the most efficiently, and who doesn't love efficiency?!
Tried saying the words “new vacuum” in front of my phone a few times. Started getting adds pretty soon afterI hear that, nothing like comparing power hitters like Lou Gehrig and Mickey Mantle to Aaron Judge and Giancarlo Stanton with your buddies, then getting a nice add selling antique Yankees memorabilia pop up in your Facebook feed. Especially when you are from Texas and never even so much as googled the Yankees. (This happened last night)
I just did that to my phone, I think we should all do it and push the google ads budget of dyson through the roof!Tried saying the words “new vacuum” in front of my phone a few times. Started getting adds pretty soon after
I don't think bigfoot has been mentioned yet...This thread is all over the place like my dreams.
NordVPN... What are ads?Targeted ads make me feel better because it means im being data-mined the most efficiently, and who doesn't love efficiency?!
I've been looking to game it so they have no idea of what I really am.Tried saying the words “new vacuum” in front of my phone a few times. Started getting adds pretty soon after
What voltage did you set the chargeverter at? Mine works as designed. Pushes 100 Amps.Since this thread has been "all over the place", I'd like to jump in. Has anyone else had an issue with the current charge settings on your Chargeverter? No matter what I do, I cannot get my Chargeverter to charge any more than 50 amps into my 4 SOK server rack batteries (they are well below absorption V). I'm using a newer Yamaha 6300isde inverter gennie to supply the power via 240v twist lock power cord. No matter what amperage I set it to for charging, the Chargeverter cuts the current in half. Signature Solar is trying to say it must be my gennie putting out too much current @ 240v which is limiting the charger current to half?? I know the gennie 240v works properly because I've previously had it running my house thru an interlok. Any suggestions would be appreciated.
I am still trying to figure out why a battery charger is called a "chargeverter". Though why the inverter is incapable of charging from a generator is a good question.Curious why so many people are buying these? You'd need them in cases where the inverter won't charge.. but otherwise? Whats the typical use case?
Was set at 57v. What type of gennie are u using?What voltage did you set the chargeverter at? Mine works as designed. Pushes 100 Amps.View attachment 137754
To me it sounds like the thing is only seeing 120v input. Make sure the plug isn't miswired.Since this thread has been "all over the place", I'd like to jump in. Has anyone else had an issue with the current charge settings on your Chargeverter? No matter what I do, I cannot get my Chargeverter to charge any more than 50 amps into my 4 SOK server rack batteries (they are well below absorption V). I'm using a newer Yamaha 6300isde inverter gennie to supply the power via 240v twist lock power cord. No matter what amperage I set it to for charging, the Chargeverter cuts the current in half. Signature Solar is trying to say it must be my gennie putting out too much current @ 240v which is limiting the charger current to half?? I know the gennie 240v works properly because I've previously had it running my house thru an interlok. Any suggestions would be appreciated.
I plan on keeping my chargeverter (charger) hooked to a grid source 24/7 and set the charge rate at 40 amps and 52.5 volts. Anytime the batteries drop below 52.5v the charger will kick in and supply up to 40 amps. 52.5v should be around 25-35% battery capacity.Curious why so many people are buying these? You'd need them in cases where the inverter won't charge.. but otherwise? Whats the typical use case?
I'll test the CV with my construction generator after this monsoon passes.Was set at 57v. What type of gennie are u using?
Do you have a clamp meter?I'll test the CV with my construction generator after this monsoon passes.
For charging batteries with a smaller generator without having to use the inverter and deal with low voltage pass through. That would be my case for future purchase. In my case I run a pair of diesel 7.5kw generators that I rotate between. I can easily charge my batteries at 100 amps with these units but find 40 amps is about as high as I can go without drawing the voltage down to about 230v upon pass through and start running into issues with my appliances acting wonky and poor light output on my LED lighting. Using one of these chargers would allow me to charge the batteries quickly at high amperage, saving diesel costs and avoiding voltage distortion. Waiting for positive feedback once these units are in service for a while. I'm concerned by the specs that state 100 amp capability however they recommend 30 amp continuous and 85 amp max charge. I have SS's 25 amp charger a d that thing gets too hot for my liking.
Thanks for explaining. I guess they had to do something with all the Warranty returned AIO's. Repurpose them as chargers with a yellow paint job.@Mattb4 "Chargeverter" sounds like a marketing name from using an inverter board, setting it up without the inverter logic and safeties in a charge-only design, and configured to accept much dirtier incoming power, because it can.
