TL;DR Has anyone done this already and found what these values are or can you help me guess the modbus register descriptions for 30020 through 30036?
Hello Everyone,
My goal is to use an ESP32 to sniff the modbus data from the inverter as well as the comms between the battery and inverter and pass the info to Home Assistant. There's a few reasons for this but mostly to filter and calibrate the values before being sent to Home Assistant and to also remove a Raspberry Pi. Don't need another computer to monitor and maintain. I'll do a nice write up here regarding all this when it's done and working.
Anyway, poked and prodded and found how to passively sniff the communication between an EG4 3000 EHV-48 v2 and an EG4-LL v2. For those unaware, this is the native closed loop communication between the inverter (in battery mode LI 4) and battery (ID 1). I have the values but unfortunately the descriptions are not documented and I have no idea what some of the values are. Searched the forums here, Google and GitHub and didn't find anything.
In case anyone asks, this communication is not documented in EG4-LL Battery MODBUS Protocol between UPS(SMPS) and BMS (Version V01.06). Not sure what they documented there, maybe its for the v1 battery or possibly the communication between batteries when daisy chained.
Here's where I am so far. The logs below are from sigrok-cli and it's the response from the battery to the inverter with real world values. I only have one EG4-LL battery, not sure if these values would be different with additional batteries daisy chained. Every two seconds the inverter sends a request, and the inverter responds with data from registers 19 to 35. The first value is the hex value, the second is converted to decimal and the text after is a description of the value. Any line with a ? is not confirmed or I have no idea.
Any help would be greatly appreciated. Thanks ?
230817: updated table with latest data
Hello Everyone,
Frame Byte | Register | Hex / Dec Received | Description |
0 | 0x01 | Slave ID 1 | |
1 | 0x03 | Function 3 | |
2 | 0x22 | Byte Count 34 | |
3, 4 | 0x13 / 19 | 0x0066 / 102 | State -- 101 Standby, 102 Charging, 103 Discharging) - UInt16 |
5, 6 | 0x14 / 20 | 0x0000 / 0 | ? |
7, 8 | 0x15 / 21 | 0x0047 / 71 | SOC - UInt16 |
9, 10 | 0x16 / 22 | 0x1509 / 5385 | Volts x 10 - UInt16 |
11, 12 | 0x17 / 23 | 0x0492 / 1170 | Current x 10 - Int16 |
13, 14 | 0x18 / 24 | 0x001F / 31 | Battery Temp - UInt16 |
15, 16 | 0x19 / 25 | 0x1388 / 5000 | ? |
17, 18 | 0x1A / 26 | 0x1BBC / 7100 | SOC x 100 - UInt16 |
19, 20 | 0x1B / 28 | 0x2710 / 10000 | ? Max Charge or Discharge x100 - UInt16 |
21, 22 | 0x1C / 28 | 0x0205 / 517 | ? |
23, 24 | 0x1D / 29 | 0x0000 / 0 | ? |
25, 26 | 0x1E / 30 | 0x0019 / 25 | Cycle Count - UInt16 |
27, 28 | 0x1F / 31 | 0x0000 / 0 | ? |
29, 30 | 0x20 / 32 | 0x0000 / 0 | ? |
31, 32 | 0x21 / 33 | 0x15E0 / 5600 | ? |
33, 34 | 0x22 / 34 | 0x0000 / 0 | ? |
35, 36 | 0x23 / 35 | 0x2710 / 10000 | ? Max Charge or Discharge x100 - UInt16 |
37, 38 | 0x36AB | CRC16/Modbus (least significant byte first, actual CRC is 0xAB36) |
