timselectric
- Feb 5, 2022
- 19,943
Just like everything else. The authorities are mandating something that doesn't have the kinks worked out, yet.
and at the top charge curve..Seplos BMS will limit to 10a of charging if a runner is detected, not sure about other manufactures, but I'm sure they do.
I'm sure some BMS handle it much better than others. A self built battery has the potential to be the best battery, because you actually care about the quality. I've used a few different brands of cheap amazon lifepo4's, and they do go wild with runners.Seplos BMS will limit to 10a of charging if a runner is detected, not sure about other manufactures, but I'm sure they do.
I could see that, depending on how much tolerance it has to declare a runner.. sometimes they run pretty darn fast.and at the top charge curve..
meaning its passive balancer can do it's job better + as it first tells the inverter to limit the charging amp before hard cutting, it is easier on both bms and inverter/charger
It also has the potential to be the worst battery ever because most people who are DIY'ing batteries are cheap bastards. LolA self built battery has the potential to be the best battery
At least they usually leave their work open, so they can marvel at it's cruddy magnificence. It's not hidden under tons of plastic and glue, dwelling in darkness.It also has the potential to be the worst battery ever because most people who are DIY'ing batteries are cheap bastards. Lol
It's me, I'm cheap bastards lolIt also has the potential to be the worst battery ever because most people who are DIY'ing batteries are cheap bastards. Lol
If you have four parallel BMSs then an BMS/string experiencing problems is not going to show up in the charger as an issue; the charger just sees voltage and current. A 20% delta in one cell of one string only looks like a <1% delta at the inverter, and the cause of that delta cannot be known to the charger.I will summon my inner Will Prowse... "show me the data that the basic concept of closed loop is better than open loop".. "prove me wrong"
Exploding balls of fire?Of course... what happens when you couple an open-loop charger to the system along with the closed-loop charger?
Closed-loop coms have the ability to give back cell-level status to the charger, and become inherently safer.
In your scenario, the BMS isn't doing its job. If you have a 20% delta on a cell, you should be routinely getting BMS protection shutdowns when that batt cell tanks or spikes.If you have four parallel BMSs then an BMS/string experiencing problems is not going to show up in the charger as an issue; the charger just sees voltage and current. A 20% delta in one cell of one string only looks like a <1% delta at the inverter, and the cause of that delta cannot be known to the charger.
I agree, that BMS isn't doing it's job. It's probably not a better idea to let the inverter decide the BMS isn't doing it's job though. A BMS is designed to interact with the cells inside it. They could be unicorn horns inside, as far as the inverter knows. What the BMS does with what's it's given by charge sources is up the to the BMS. The charge source just needs to know when to stop.. that used to be based on voltage.. now it's based on something in the closed loop communication, what, I'm not exactly sure.In your scenario, the BMS isn't doing its job. If you have a 20% delta on a cell, you should be routinely getting BMS protection shutdowns when that batt cell tanks or spikes.
In some ways sure. A large subset of DIY'ing is using things in creative ways for a variety of reasons. Nobody was talking about using this AIO in any type of weird way though, just hooking up commless batteries to it, as has been done for generations in the back country.Saying you're going to be on a DIY forum and expect a manufacturer to honor a warranty is like being on a car tuner forum and bitching that Toyota won't warranty a blown motor you tinkered with.
I would think it would only alarm if it was configured for closed and had to fall back on open due to comm breakdown.Do we need to avoid future updates?
To make sure that we don't end up getting a constant alarm about not having closed loop.
Or is this going to be an issue, right out of the gate?
It probably has a setting for lead acid vs lifepo4. They could have it just harass lifepo4 users and not lead acid users.I would think it would only alarm if it was configured for closed and had to fall back on open due to comm breakdown.
Otherwise that would tick off every LA user.
It does have a setting for lead acid vs lithium, and it also says to use the lead acid setting if running open loop.It probably has a setting for lead acid vs lifepo4. They could have it just harass lifepo4 users and not lead acid users.
With BMS communications. The BMS tells the charge controllers when and how much to charge.UL-9540 (A)
Seems to require the battery to pass the fire test without closed loop communication.
UL-9540 (Ed.2) talks about ESS having an Inverter that is tested together with it and certified together but I see nothing about closed loop comms being required. Did someone else find a section that requires that? These documents are extremely boring to read.
I am still looking at the other certifications in regards to the Inverter itself.
I have never seen an Inverter that can read battery voltages at the individual Cell level.
The only reporting from the BMS is the total Voltage, Current, SOC and Temp. All individual cell management I have observed is done by the BMS itself.
If one cell is at 3.75V and the other fifteen are at 3.30V the INVERTER treats the pack as though it is at 53.25V and charges the cells the same way as if all 16 cells were at 3.328V. It is the BMS itself that will try to discharge the one high cell into the lower cells and balance back the pack.
I am open to seeing or hearing something different but I have not personally seen or read of an Inverter doing a single thing to fix or stop an issue with a bad cell. If someone has seen something different I would love to hear about it.
