cs1234
Solar Wizard
- May 9, 2022
- 2,834
inverters catching fire was never mentioned. this mistake seems to be a good way to keep your rant going.
Pls do something better tonight.
also not a lux requirement. your facts are made up again
Whether it's the EG418k branded inverter causing fires with open loop batteries, or lighting itself on fire because it allows open loop in the firmware but doesn't fully support it as other inverters in the past do is kind of irrelevant. Unless you are saying that all the past inverters by you and other companies all have what is now deemed excessive risk of making open loop batteries catch fire?
Or is it something about the design of these new eg418k inverters that causes open loop batteries to possibly catch fire? But with closed loop batteries they are much safer than other inverters of the past, to the point the open loop sacrifice is worth it?
Hopefully you will fill us in on all the details in the announcement/post you mentioned a little while ago in this thread.
It's nice that you participate in threads here, but you shouldn't talk trash to people. It isn't a good look for a company representative. Even if you feel we are being mean to you, you should turn the other cheek, take a breather and temper your reply.
