Will and David Poz, I believe have tested these EG4LL server-rack format batteries with high marks.
https://signaturesolar.com/eg4-lifepower4-lithium-battery-12v-400ah/
Can they be mounted in any orientation? For example on the small side? I want to mount under the RV dinette. The base is not deep enough to flat mount.
I did email signature solar (both sales and support). They haven't responded. While not a great sign, I did see a message on the site that they are having issues due to weather.
Battleborn confirms that LiFePO4 chemistry batteries are mountable in any orientation due to limited electrolyte. I assume then, this would apply elsewhere.
Can anyone confirm for EG4LL batteries? The installation manual doesn't designate. Just that they should be securely mounted.
Note, In another RV application, I installed EVE 280Ah cells on their sides with no repercussions, at least @ 2 year mark.
Thank you,
Doug
Thank you,
Doug
