Solarcabin Channel
Well it does seem like there will be much more options for COLD climates next year.. under the program Trane field tested one last year:
Lab tests for Trane’s CCHP prototype were performed at the DOE’s Oak Ridge National Lab Facility in temperatures as low as -23°F, which surpassed the mandatory -20°F DOE requirement. Even as temperatures moved beyond the trial scope, the prototype continued to operate at a high performance
I have been following the progress and I hope they are successful.
I think you will find the Trane (and Mitsubish) units are getting around the threshold by using an inline resistance heater to boost output below freezing but that also also takes more power.
The reason I don't recommend them for cold climates as a primary source is because current models struggle below freezing but also because they are complicated pieces of equipment that an average homeowner can't repair and replacement parts are not off the shelf like other heat sources.
JMO and I know other people swear by them!
