How much compression?These batteries are sparking like crazy. Maybe the compression wasn't such a good idea. I'm thinking that these are the cheapest Chinese product I've ever dealt with and I can't believe no one has this problem. Internals of the cells are trashed.
But is sparking common when adding bus bars?It is common. Very few of my cells aren't that way, and those have at least some voltage showing at the case relative to the negative pole.
Kapton tape is cheap, and will help insulate the cells from each other. The PC board fiberglass separators work very well also.
There should only be sparking when there is a load. That load could be a result of current flowing from the case through the electrolyte to the cathode or anode. I don't believe that either terminals are connected to the case but I did take the above precautions and insulated between cells and I insulated the thread rod and did not place the cells on anything that was conductive.But is sparking common when adding bus bars?
You bolted the cells together without insulators between them, this creates a connection between cells, because as you found out the case is not isolated from both terminals.I bought (16) of them from one of the members in this forum who bought them from Docan. I used the same board they make computer boards out of between the cells and they have held up good, no bulging. They have been charged to 3.55 volts. The cells have never been assembled into a battery and can't be assembled into a battery. I don't know how much compression. I used threaded screws and wooden ends pieces. I don't think it is safe to video tape them.
Please post a photo of the cells.
The batteries cells came with terminals. I inserted computer board between the cells before I compressed them. I'll check the video and see if there is a better way to insulate them. The cells are leaking big time. Pictures are attached above.You bolted the cells together without insulators between them, this creates a connection between cells, because as you found out the case is not isolated from both terminals.
So, when you tried to install the terminals, you created a circuit. Terminal to case to other case to terminal on other battery and then added the bus bar. You created a short circuit.
Add insulation between the cells as recommend above. Also between the cells and any metal of the enclosure.
Also, all these cells are built the same way. The case is connected to one terminal.
"But is sparking common when adding bus bars?"
Can you clarify that about the spark?
It spark when you touch which part to which part?
