Sun in Lithium
Northwest Alberta Solar supplier/installer.
- Nov 10, 2020
- 157
Or you could just check for continuity between the cell casings, with your multimeter. By placing the leads on the QR code of the cells beside each other.
To be clear, the flat part of the cable lug should be fastened by the screw to the BMS port. Overkill has a fairly extensive instruction set. For more surface area two or three positions are available for attaching multiple smaller wires all going to the same battery terminal or bus bar, as seen in the picture you posted above.Can the screw hole be skipped and the 2/0 AWG wire connect to one of the terminal screws?
Yea, I combined it with under 2 minutes of searching the model number on duckduckgo...
The last picture is a different BMS. If yours is the one in post#46 & 47 just follow the pictures.How do you get the wires to the battery? What I see is two bus bars over B- and C- but I don't see the black wires and the blue wires going to the battery or the load.
Lug your big wires to the bus bars you install. Somewhere right in the middle would be great. Drill the proper size hole, pass a stainless bolt through from the bottom, and put your lug on and then a stainless washer and nut.Yes it does. How do you get the wires to the battery? What I see is two bus bars over B- and C- but I don't see the black wires and the blue wires going to the battery or the load. So, I guess I don't get it. Sorry, I'm dense.
