OK, here it is. Been working on this for a couple months now and gotten feedback on individual pieces but not the whole setup.
Have already received the 4 300W panels and ElectroDacus SBMS0 w USB/WiFi and DSSRs and ordered the Li cells (March ETA) w enough bus bars for all terminal connections shown.
About to purchase everything else but would appreciate any red flags or adjustments that might be needed before I do.
Heavier weight red/black wires will be #3 AWG and the rest #10. Heavier weight grey wires are grounded AC cords w 3-prong plug connections at the inverter.
All AC appliances and 24V DC consumers are shown and are switched via Sonoff (RF, EWeLink/IOT, or by pressing manual buttons on the unit) using the Normally Open terminals.
Electrodacus SBMS0 includes:
Everything in this list that came w an AC adapter has been converted to run straight from DC. Will use buck converters to adjust supplied voltage where needed.
I calculate that worst consumption days (when I might have to work) will require about 4kWh, which will bring me down to about 50% SOC from full or, more likely, 40% if I don't charge 'em all the way up to 100%.
Because it'll take me about 7 hrs of sun to replace that, I've designed space to add another 600W (50% more) of solar which will get that number down to about 4.5 hours.
Rest of the time, I'll probably only be consuming about 1-2kWh per day.
All these calcs assume I'll only capture about 50% of the rated capacity of the panels on average. Would an MPPT improve this? Probably not enough to make a difference. I sized my panels to get near MPPT performance.
Why 3 laptops? I'm an IT Consultant. ;-)
But I'm not an electrician or an EE so any advice/feedback greatly appreciated!
- 8S cell balancing on charge and discharge
- HV and Low Temp (XT1) Cutoff via EXTIO4
- LV Cutoff (AC & DC) via EXTIO3
- CHARGE current monitoring = current at PV Shunt (1-direction)
- LOAD current monitoring = CHARGE current plus current at ADC1 Shunt (bi-directional)
- 12 months of historical and RT reporting/charts on SBMS (& on a PC via WiFi)
- Downloadable data files via USB
V A W
12 2 24 Engel Fridge
12 2 24 Fantastic Fan (to be replaced by Maxair in near future)
19 2 38 27" Computer Monitor
20 5 90 Laptop #1
20 3 64 Laptop #2
15 6 90 Laptop #3
12 1 12 Apple TV
12 1 15 Echo Spot
12 1 12 Mofi LTE Router
12 1 6 WiFi Router
12 0 1 Natures Head Composting Toilet
12 3 30 Water Pump
5 1 5 Phone
5 0 0 Toothbrush
5 1 3 Waterpick
n.a. 28 414 TOTAL
