Allright so I am thinking of ordering this BMS to work together with my 4*200ah cells.
I will be using it in a RV and it will charge through 300 watt victron mppt solar charger and through the vehicle alternator when driving.
Normally it is recommended to use a charge booster (battery to battery charger) to charge using the vehicle alternator. If not, your alternator might be using itself 100% to try to charge the battery asap. Therefore they recommend a 30a charge booster (So that the battery charger at maximum 30a and not using the alternator for 100%).
If you are referring to a DC-DC charger like this one (I've heard devices like this called DC-DC charger, and Battery to Battery charger, but not charge booster so maybe you mean something different than what I'm thinking of) than I think you are understanding correctly that one of its primary purposes is limiting current so as not to overtax the alternator, additionally it will have a charge profile for lithium batteries, and can step up or step down the voltage.
I would respectfully disagree with @HRTKD using a DC-DC charger (or some other form of regulation) between vehicle charging system and lithium batteries is somewhere between strongly recommended and a requirement in most situations from what I've read. From what I've heard, In the olden days of lead acid, the system was naturally self limiting due to the battery chemistry, but this is not the case with lithium, so to prevent a stock alternator from running flat-out and overheating, a DC-DC charger or an external regulator is needed.
Now my question is:
- Can you set the maximum charge rate on this BMS (using bluetooth).
If that would be possible, I guess the charge booster (in this case more limiter) is not needed. Am I right?
I'm pretty sure the BMS can't and shouldn't be used in the way you are hoping. I am only modestly informed on the topic, but I am not aware of any BMS capable of current limiting. Overcurrent protection, even if adjustable is a simple on/off. Further, its not clear (to me) whether BMS overcurrent protection is a battery protection feature or a BMS self protection feature, or both.
