Fire departments around the world are buying large shipping container to drop burning EV cars into and submerge.
hang the 19 inch rack from plastic ropes of the ceiling - above a water barrel or pool.I really like the idea of my batteries living on a cart, right next to the door. Yank the fire out the door and head for the neighbor's pool.
Did you use the TIGOs ?RF smoke alarms. Big red Emerg shutdown switch outside power shed that shuts off all PV inputs and 240VAC outputs. 40 lb CO2 plumbed over batteries. 1/2" ceramic fiber matting between all 10 16S 280aH batteries. 1/4" concrete hardibacker over and/or under all batteries on my heavy duty double shelf wood workbench. 100' from house.
I'll bet a nickle your idea has been snatched up by the net snoopers and is on the drawing board. Nice one eXodushang the 19 inch rack from plastic ropes of the ceiling - above a water barrel or pool.
If it starts burning - the ropes disintegrate and the whole thing drops into water
I like low tech solutions. I work very high tech and bleeding edge, but always try to simplify as much as possible.I'll bet a nickle your idea has been snatched up by the net snoopers and is on the drawing board. Nice one eXodus
Sounds like the same principle as fire sprinklers.
water has a very high density and needs a ton of energy to boil. I'm would be more concerned about a server rack falling into the barrel and spilling all water before it can do any good probably need to add a aerodynamic nose under the rack so that the splash is not as violent and does not disperse as much water.Do the math (on stored energy and latent heat of vaporization), determine if there is enough water to keep battery covered, or if tank needs to be deeper or automatically refilled.
Sol-Ark has two terminals. I used a large red button with SPNO contact. I have to push it in for 3 seconds.Did you use the TIGOs ?
What is the actuator for the CO2?
Everything else sounds like mine..
Reminds me of the story of the little girl that went with her Dad the local sheriff to an accident. It was a tractor trailer stuck under an overpass. The overpass was too low and the trucks trailer got snagged. The wrecker driver was there, a state trooper, local deputy and they were all discussing with the truck driver on how best to solve the problem. The engineer said "lets remove the asphalt, raise the I-beams and reconstruct the bridge after removing the truck. The state trooper said, no, we'll have the truck removed by calling in the national guard they will know what to do. The tow truck driver said "we can bring in 4 more tow trucks and attach them together and pull the truck out". The entire time the sheriffs little girl had been tugging on his shirt tail and he kept telling his daughter to wait, wait till we get this fixed and we'll go get ice cream, just a few more minutes. The men kept discussing ways to get the truck out and the traffic that was backing up was getting bad. The little girl continued to pull on her daddies shirt tail. He looked and forcefully said "what is it?", she said "why don't you just let the air out of the trucks tires?".Can you solve this problem with a stick or a sticker? Stick stands for "simple tool or part" and Sticker/decal stands for "simple obvious communication" We (engineers) tend to overthink things.
Lol I actually lowered the air in tires once, to get a Van into a garage, was just missing a inch of clearance.she said "why don't you just let the air out of the trucks tires?".
I knew about the terminals but thought it was just for TIGO shutdown.Sol-Ark has two terminals. I used a large red button with SPNO contact. I have to push it in for 3 seconds.
A manual valve/regulator for CO2, plumbed with soft copper line.
Yes. You'll see the alarm, no beeping. Push power button for off on both, then agsin and eveything is back online in a minute or so.I knew about the terminals but thought it was just for TIGO shutdown.
So if you connect anything to those it will shut down the PV and electricity production?
Do you just reboot after such an event to restore normal usage?
Cool thanks! Learn something new everyday.Yes. You'll see the alarm, no beeping. Push power button for off on both, then agsin and eveything is back online in a minute or so.
