Toinfinityandbeyond
My name is Gary and this is my first post to this forum. So, Hello everybody.
I have a 6500W 48 Solar Charge Inverter with six 415W panel connected in series.
1. Anyone know if the inverter is Bonded?
2. What DC amp disconnect do I need between the panels and the inverter.
3. What size disconnect do I need between inverter and my two 5.12KWH POWERWALL LIFEPO4 LITHIUM BATTERY SG48100M?
4. Finally, from AC out to my breaker box, what AMP Main breaker should I be using?
5. If the inverter is bonded, then my Earth Goulding Wire should go to the inverter, correct? If not, then it should go to the Breaker box and the breaker box would need to be bonded. Correct?
Really do appreciate any input and suggestions. I want to be sure my calculations are all correct for this.
