Hello there! I'm in the great state of Arizona and looking into a DIY ~30,000 kwh ish system.
I'm basing my system usage off my last 3 years of elec use with APS (power company here in AZ). As seen in image one, I used 29,189 kWh's between 2019 and 2020. Between 2020 and 2021, I used 26,183 kWh's. This was in a older home (built in early 2000's), 2 story home with about 2600 SF in Phoenix AZ
I recently built a new home here in Arizona and so far for 2021--2022, I've used 14,205 kWh's (9 months of the year so far, with the hottest months of the year just ahead of us)
My new home is about 2500 SF, single story. I don't have any shading on my rooftop. I do plan to add an RV garage here in the next 3-5 years and add a mini split? AC unit in the current garage along with the RV Garage.
Based on what I'm seeing so far with my new house, I'm using about half the usage from my old house, but as stated, I want to leave some wiggle room from 2x mini splits and maybe a EV in the future.
I would like to be grid-tied and to sell back to the power company if need. I would also like to have the system stay on line if we lost power and the grid went down.
I have a budget of ~35K for everything.
Some questions regarding hardware:
I'm not sure what I need. I plan to have this on my roof and currently working with a company to do the design on my roof. They are building it off my blue prints of the home. So far, they are recommending 50 SolarEver 410w panels with IQ8+ micro inverters.
Thank you so much for reading my novel. I'm just starting to research more and more of this and figured it would be best to have it all in one place as I come up with more questions, just easier to follow for me when it's all in one place.
Thanks again!
- Regarding the solar panels, how is SolarEver compared to Jinko? Do they both use micro inverters?
- New/used, does it really matter? I'm looking at buying from SanTan Solar which is here in AZ.
- New SolarEver 410w will run me about $250 each. X50 = $12,500
- Used Jinko 400w will run me about $130 each X 52 = $6,760 (adding two more to cover the extra watts... this is just my basic math)
- Can I use used solar panels in a grid tied system?
- I'm thinking about going with 2 Sol-Ark 15K systems as recommend by someone on Facebook, would this cover my needs?
- Good? Bad? Cheaper options?
- I'm not trying to go "cheapest" route as I want something that can grow if needed and as needed and not tied to one company. But don't want to spend extra money if not needed.
- Batteries - I got a recommandition of something like a 40 kwh system. Does this sound correct? How long would this last me? Looking back at my largest month in the last 3 years, I used 4,769 kwh for the month of Aug, 2020
- What else should I be researching regarding hardware? I just don't know what else I will need. I understand some wiring and a mounting system, that's simple enough. But what other parts to the solar system will I need for a grid tied, battery backed system?
Thanks again!
