First time PV system and bat.-pack builder. EU, mid-south Sweden.
Main question:
1 - Can I use the Victron SmartSolar 150/45 MPPT with 2s500W PV (probably tiltable at stationary) and JKBMS B2A8S20P-HC to top-balance new EVE 8s280Ah first time (no load/inverter connected), when they arrive? If possible. Is there a guide for this specific balancing-configuration?
[EDIT-Answered] Secondary thought:
2 - I am a little bit confused about the fact that both SCC and BMS have specific settings for voltages, etc. Bulk, absorb (and float, Pb legacy). Could this not lead to conflicts of any kind? Or is it the BMS that dictating to SCC "I now want this specific Voltage and you give me exact what I want" and the SCC complies as an obedient slave and serves to the BMS exact what BMS desires?
[EDIT-Answered] 3 - Is the internal resistance in batteries the most important factor to match when building a bank from new cells? Does responsible suppliers of cells match both voltage and resistance? Example Luyuan? What is generally considered good span of resistance-differencies on new, delivered, matched cells from a reputable, responsible supplier?
Preferably. Single assembly (no re-assembly), balance with PV+MPPT+BMS (no load connected), production with load connected. If possible.
Prefer calm, conservative, patient way. I want things get done correct. Aiming max 0,5C charge/discharge. Not planing cycle 100% capacity. 90% -ish OK. Best would be to seldom go lower than say 40% SoC?
I am quite reluctant to invest in (or build/modify) special chargers just for first balance and after that the equipment would be sitting for ages with no need of use, collecting dust. Especially since JKBMS have active balance function. Even if such a charger could cost only 50$ or so. Just seems wastefull. Have been trying to read up as much as possible, mostly on this forum, about what needs to be done, how, why, to achieve desired end result. I have now some understanding that there are more than one path, how to balance a bat.-pack. I am also some what unwilling to reconfigure s-p-s just because of first balance, pre-production.
Circumstances:
At the moment total renovation of the caravan. All wood rotten. Alu skin good, keep. Hopefully I finish renovation and OFFgrid build to get at least some weeks of warm days aug-sept before autumn kicks in.
System:
PV 48V
Bat. 24V (7,1kWh)
Consumers 220V
100W (450?W surge) small house-fridge
800W rated simple microwave
45W laptop
Handfull small lamps
Estimated consumption 1-2 kWh/day
Bought - PV 2s500W STC 44,22 Voc - STC 14,04 Isc
To Buy - Victron SmartSolar 150/45
To Buy - EVE 8s280Ah double-threaded terminals
To Buy - JKBMS B2A8S20P-HC (heating function, cold climate winter)
Bought - Nova NV-P1500 1,5kW (3kW surge) 24V-220V pure sine inverter
The inverter is simple, no com-port of any kind.
Not studying/buying any cables/breakers/shunts/etc at the moment. Now all focus renovate caravan, study OFFgrid electronics and buying major components. Purchase cables/breakers/shunts/etc and final assembly, as last step.
Aside of main question about balancing. I am also gladly opened to any critics of the system design or choice of main components.
Considering to buy from Luyuan since people seem to have very positive experience with them (Amy?) and if I understand correct, they have an EU-stock, meaning no extra customs, VAT, etc and short shipping times?
Main question:
Circumstances:
System:
PV 48V
Bat. 24V (7,1kWh)
Consumers 220V
45W laptop
