Yes. The BMS is pretty big. Always the BMS that goes bad. If you check the voltage on each of the cells, they are all at the same voltage. I have not seen a bad bank in these. It is always the two sets of positive/negative wires that show bad voltage. I never smell anything burned or see any signs of short on the board. The SCC and the inverter portion works great along with all the inputs and outputs. When you change the BMS out.... Connected to the display portion you will see two ribbon cables. Since one of the ribbon cables goes to the battery.... The part that goes to the battery on the old BMS has four wires. The two on the outside are labeled “+” and “-“. (As shown on the other end that plugs to the display. I just put a ring terminal on those two wires and attach then to the main board where the screws are holding the positive and negative wires to the inverter. (Red/Black wire). Then everything will work no problem. Voltage of the battery will be shown on the display correctly.
