thanks for the answers.
I have a flexible panel, brand new (at least supposed to be)
55W , dimensions 565 x 530 mm, 32 SunPower Cells.
I saw several youtube videos, one of them a guy (Julian Ilett) even in UK was getting 20w from his 20W panel . I live in northern italy would expect the sun to hit harder in summer.
But if you guys think this is normal, I'll acknowledge this. I'm new to the whole solar thingy.
I was wondering how they arranged 32 cells to make a square panel.
Turns out it is like KFC's "10 pieces of chicken". They cut each of what we would call a piece in half, and technically they now have twice as many pieces.
Find many great new & used options and get the best deals for 100w 12v Sunpower Flexible Solar Panel Battery Charger for Car RV Marine Boat at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Find many great new & used options and get the best deals for 2 Pack 50W Flexible Sun Power Solar Panels at the best online prices at eBay! Free shipping for many products!
www.ebay.com
We ship in 1 Business Day. High Power and Flexible Made with SunPower’s highest power Gen II back contact cells, SunPower’s flexible panels deliver the highest power output and the highest charging capacity in their product class. SunPower‘s panels are constructed with top-grade, light-weight...
www.ebay.com
Depending on how wired, that might or might not help with partial shading. Bendability? Only helps in one direction.
Apparently some of these little panels are branded SunPower, while others are made from SunPower cells.
Everybody knows that matching cell current in a panel maximizes power, because the panel will be pulled down to lowest current of any cell.
Same goes for panels in a series string.
Probably many manufacturers buy cells, assemble panels, and (if you're lucky) rate the panel according to stated power of the cells.
Real panel manufacturers flash test the panels to measure output. That is after they bin cells, so they can assemble some panels for higher power and charge accordingly. At the low end of products, of course they would just slap them together fast.
You can easily have been testing on a day when sun was < 1000W/m^2. We assume you oriented the panel directly toward the sun.
"I live in northern italy would expect the sun to hit harder in summer."
Ahh, there's your problem. We tell Italian jokes over here.
The sun probably did hit harder in the summer. You got Isc = 79% of label rating, which represents 1 standard sun and panel at 25 degrees C.
Try cooling it with air conditioner or whatever, then measuring immediately upon aiming it directly at noontime sun. Although, apparently heat has more impact on Voc and power than on Isc. You may have about 800W/m^2 rather than 1000W/m^s
Did you test all panels? That would rule out single defects (but would follow variations in lowest-output cell, at least at Vmp)
Measure current shorted, which should be less sensitive to temperature. Power, and current at around Vmp, will definitely be lower when hot.
