twmangrove
I am replacing a Xantrex PS 2000 inverter which recently died. I sent the following message to Giandel:
"I am considering the purchase of this inverter and I see that it has a 20A solar controller. My RV has a solar array and solar charger connected to my battery bank but I'm wondering if I can add additional panels and connect them to this inverter to increase my capacity. The solar production from my current array is not great." I then received the following reply: "
Thank you for your reply.
Confirmed with our engineering team, it is workable , but the extra solar panel should not exceed 300 watt.
Would anyone on the forum care to double-check this for me? By the way, even if adding additional solar panels is not advised I will likely still buy this inverter. I currently have aging AGM batteries and will likely change to lithium in the near future. Perhaps the Litime 12v 100AH ones reviewed by Will Prowse.
Thanks,
Thanks,
