I have recently purchased 3 power queen batteries to do a budget build on an EZGO golf cart. Ran the cart about 15 miles which i found impressive considering the previous Lead acids barely made 5 miles. Went to charge the packs since i was reading about 30% power left, and hooked them all in parallel to a victron blue IP-65 15Amp charger. It went through the full charge cycle and showed that the batteries where all fully charged, but when i try to run the cart again the first battery in series instantly opens the circuit as if it was under volting. Im almost to the point of ripping all 3 batteries open and just making a single 36 volt system. Is there any ideas on how i could further test the current batteries, and if not any suggestions on what BMS to use for a 36 volt system.
The cart is a 1995 that i rebuild pretty much from ground up, with whole frame being rusted out. Hence the budget route
