Wouldn't want to bend the smaller cylinder with what the bucket cylinder can push against it even with a pressure relief, plus with bigger cylinder can pick up heavier objects and grab bigger loads than smaller cylinder.I would think a small cylinder could move the thumb and lock it into place by means of a lever, strong enough for bucket to work against.
But a hefty cylinder would be the simpler design.
Strong enough cylinder to bear the for and hold the thumb at any angle instead of getting off and locking for each angle you want to grab from. They do have those that are just of mechanical locking in certain position and that's it.I mean a mechanism similar to a load binder (but push not pull).
Then a small cylinder can work the lever to extend and lock thumb. Reaction from bucket would bear on the mechanical part, not on the small cylinder.
Another excuse to fabricate something and weld naked?
Of course, strong enough cylinder to bear the force and you can hold the thumb at any angle desired.
I have two Ford 4500 backhoes, one for parts and that's where I got my cylinder from. Just had Discount Hydraulic custom make the lines, I bought a Prince valve from Surplus Center and will make a custom pedal control to run it.Surplus Sales of Nebraska commonly has hydraulic cylinders for sale relatively cheaply. I built my grapple around a 3"x 8" cylinder that I bought from them for $75. Lucky for me, I bought two. I just swapped them out when the wiper started to leak fluid, then rebuilt it at my leisure.
I would probably build up several parallel smaller electric motors on one pump and control them in stages to keep pressure at about 2,300 PSI and then just run everything on fluid like HST tractors do. My 28 HP tractor is rated at 6.5 Gal/Min at 2,350 PSI. You could probably get decent results with a 1.2 Cu. In. displacement pump and 20 HP total of electric motors. You could run one larger pump with several motors on clutch drives, adding motors as the RPM drops below the rated input RPM at the pump shaft.anyone have recommendation of a current EV tractor?
40 horsepower is ~30,000W without losses
not trivial but still within reason fer DIY and even shop sold.
any suggestions?
Yep, a bulldozer is just that a tractor till you add attachments since it can push or pull and do everything a tractor can do if outfitted right, same with track loaders.According to the method of movement, there are two types of tractors: wheeled and tracked.
OMG!One of the best deals out there if you are willing to do your own repairs are the government surplus Special Emplacement Excavators (SEE) otherwise known as FLU 419s. Its a wheeled loader with Case backhoe in the back. The US military had 3000 of them made by Mercedes based on their Unimog 406 chassis to fight the expected ground war with the Soviets in Europe. By the time they got delivered the USSR was no more. Most sat in depot for most of their lives so the hours are low. In order make work for various congressional districts many were torn down and rebuilt to new (recapped) and then sold as surplus. Mine had 41 hours and 500 miles on the speedometer when I got it. I paid 17 K for mine 4 years ago, folks are asking $27K on Ebay but my guess most are being sold for less. They are complex machines and US Mercedes dealers have no clue how to work on them. They were imported as Freightliners but they were strictly sold to the military. Manuals are available on line.
They have a 4 speed transmission with an air splitter and high low range box. Its Mercedes 6 cylinder Diesel with mechanical injection that has been around for many decades. They are either 2WD or 4WD with front and rear diff locks.
They do not take a 3 point hitch as the backhoe arrangement prevents it. I have plates on mine and some claim they can go 50 MPH but anything over 30 MPH on mine exceeds my level of fun (short wheelbase makes it pitch front to back and off road tires and suspension makes it pitch side to side. Its got an auxiliary hydraulic system with 50 foot hose reels that fit Stanley Hydraulic tools. They came with the jackhammer, rock drill and chainsaw (but the tools may have been lost).
The underlying running gear is built for 250K or service. Beats buying a third hand beat up crawler loader or much lighter chinese or indian rebranded unit.
Watch a whole video!OMG!
You ABSOLUTELY HAVE TO INCLUDE PUCS WITH A POST LIKE THIS!!!
