Ahhh...I was using imperial tons. No wonder the math was not working out.Like Megacraptonnes of water. That a metric unit BTW.
The average urination flow rate for men over 45 years of age is 12 mL/s ~= 0.012 kg.s⁻¹I wonder how much power the 3ft drop can create.
Biggest problem I see is men's notoriously poor aim. I can see some sizeable efficiency losses attempting to direct the flow onto the mini turbine blades.0.012 kg.s⁻¹ x 1 m x 9.8 m.s⁻² ~= 118 mW
If you meant to me (or others)...I am starting to "Get it". The idea is great,clean,free (as in not costing fuel or money)... but is not really "usefull" on a small scale. Only as a learning experiment it's a good project, but not as another way to charge my phone. That message got through. ?My goodness. I guess the math just doesn't get through.
Except what it costs to design, purchase, build, operate and maintain it.as in not costing fuel or money
He's got the maths ?The average urination flow rate for men over 45 years of age is 12 mL/s ~= 0.012 kg.s⁻¹
Call it a drop of 1 metre.
Lol..If you meant to me (or others)...I am starting to "Get it". The idea is great,clean,free (as in not costing fuel or money)... but is not really "usefull" on a small scale. Only as a learning experiment it's a good project, but not as another way to charge my phone. That message got through. ?
I have also been looking at hydro generators in various forms...but you need massive amounts of water to make that work. For an experiment a pump is fine to get water up in a bucket and run down some waterwheel or turbine. I will at least try both these methods to light some LED's but other than that it might not produce enough power...or for long enough to be really useful for other devices.
I did do a quick test by putting the small generator directly into my "bosch dremel-like tool"...it fit's perfectly. It generates 40 volts at speed 1 and increasing it gave 60, 80, 100, 115...after that I did not dare increase it any more in my current setup. Also...I have no idea at what RPM the tool is spinning the generator. Probably more than what it was designed for. I know volts do not equal watts or power...it will still only give a max of 10 watts. Right?
But at least I know that at a high enough RPM there will be enough voltage on this thing. It's a cheap thing from amazon...even cheaper on aliexpress ?
source: borrowed from google
Let 8 kg freefall from 5 meters to turn a generator. Put all this energy into a small portable battery pack. If you set this weight 10 times a day, by bed time you will have enough charge in the battery to get 10 watts for 15 minutes.If you meant to me (or others)...I am starting to "Get it". The idea is great,clean,free (as in not costing fuel or money)... but is not really "usefull" on a small scale. Only as a learning experiment it's a good project, but not as another way to charge my phone. That message got through. ?
Nah, he missed the time factor. That's 118 millijoules, not watts.He's got the maths ?
Just keep on drinkingNah, he missed the time factor. That's 118 millijoules, not watts.
Nope, seem like he used flow rate per second and joules per second =wattsNah, he missed the time factor. That's 118 millijoules, not watts.
Do you urinate for 1 second?Nope, seem like he used flow rate per second and joules per second =watts
Now that is a way more constructive and motivational reply! ? Only issue is I can't create a height of 5 meters...as my ceiling is at 2.5 meters. I can do a pulley system...which will also minimize the load/torgue/(whats the term) on the gears that pull it back up. And maybe the motor.Let 8 kg freefall from 5 meters to turn a generator. Put all this energy into a small portable battery pack. If you set this weight 10 times a day, by bed time you will have enough charge in the battery to get 10 watts for 15 minutes.
Similar for hydro. A trickle of water making 5 watts continuous adds up if stored and used later.
I have build my own 3D printer a couple of years ago...then bought a real one...and dismantled the old one. So I have many parts in servo's, beams, slides, bearings, belts, wheels, pulley's...but most are 5mm. And this generator has a 3mm axle...still looking for those gears in this size. 3D printing is an option...but not durable and my 3D printers are "temporarily out of service".I have 4 if those mini generators, with all gears and stuff.
I have the same with my solor system. Return of investment...NEVER! Or your version..10.000 years. But the fun and learning is so worth all of it! If only I had the space and budget to expand it...I would in a heartbeat! Truly offgrid...but in the city. Hahaha. I am not an outdoor person but I just like all the related tech. ?Idea was to make a water wheel at our pond filter, to get some of the energy used back.
Return in investment?
Lol
Like 10.000 years
But fun.
Never went into fruition...
But does not breakdown either..
Patiently waiting on a shelf ?
The fun of design was already worth it
