Exactly what I am thinking also for my setup. Seems like everyone just puts them this way.I will connect (or at least was planning to...) the inverter's ground to the house ground.
That's where this whole issue started with.
I suppose that my inverter does Neutral to ground bonding internally when in battery mode. Even if it doesn't, I can achieve this bond using the inverter's external relay and an AC contactor.
This isn't the issue.
The issue is that the house ground is also bonded to the house/grid Neutral, and my worries are about having 2 Neutrals (one from grid, one from inverter's NG bond) on the same ground.
EDIT: On a second thought, obviously these machines work with the same neutral when ac IN is working and grid is not down.
In theory the issue happens only when grid is down. But then maybe it doesn't matter as grid is down.
