can solar panels and grid be put in pv input together?Several options.
Either use an inverter charger, or get a power supply and feed it into the charge controller on the PV input.
Grid cannot be put on the charge controller unless you have grid connected to a dc power supply.can solar panels and grid be put in pv input together?
After looking at Wills videos do I need an Automatic Transfer System like the one shown on the video "DIY 2000 watt, 24v Solar Power System w/ LiFePO4 Batteries"Grid cannot be put on the charge controller unless you have grid connected to a dc power supply.
Can you post a link to the video?After looking at Wills videos do I need an Automatic Transfer System like the one shown on the video "DIY 2000 watt, 24v Solar Power System w/ LiFePO4 Batteries"
Which inverters have the internal transfer switch?Some inverters have an internal transfer switch. They function like a UPS - if grid (shore power) is available, it supplies the load. When not available, battery supplies load. If inverter doesn't contain it, then can be external (or use a battery charger as Supervstech says.)
More difficult is using up to 100% of PV to supply load plus additional power as needed from grid.
Without grid, up to 100% from PV and balance from battery is normal operation.
Once you size your planned system (Wh of battery, W of PV, W of continuous AC, W of surge AC), you can compare various AOI or individual components.
