Looking for recommendations for wiring enclosure and components inside to mount on a ground mount array. This is for 5 separate PV strings that will all have separate runs back to the charge controller. Max Voc would be 450V. What I was thinking so far is:
I know Midnite and others provide 1000V 30A touch safe fuses but those aren't rated for disconnecting under load.
I also know about the IMO disconnects but with 5 strings would need to get their 8 pole one plus another 2 pole one which seems excessive.
There must be a simple solution I am missing.
- Vevor 16x16x8 metal enclosure
- 5 Midnite Solar MNSPD-600 surge protectors
- din rails
