Definitely NOT an electrician... but... in the US the way 240v split phase works is a centertap off the transformer, so:If I am not mistaken the ground wire is actually also connected to the negative line as is the power pole negative line . If there is an electrician out there you might explain that . I'm in Aus with a 240Volt single phase rural supply.
OK as I said its Single Phase here not Split and I corrected the negative comment below . The edit 20min limit got me again.Definitely NOT an electrician... but... in the US the way 240v split phase works is a centertap off the transformer, so:
There is no "negative" wire in AC power
- L1 to neutral is 120V
- L2 to neutral is 120V
- L1 to L2 is 240V
Somewhere, usually close to the meter, a grounding rod is hammered into the earth (there may be multiple grounding rods, each needs to be electrically connected). The ground from your load center is tied to the grounding rod.
Somewhere, usually the Load Center, the neutral is bonded to ground.
Briefly when you install your solar panels on your roof or permanent position ,the frame and the panels ,are all strapped to earth . There are special connectors made for earthing each rail and for joining one rail to another . They are meant to bite through the anodising of the rail .On the ground side an earthing rod is usual that is driven into the ground as close as possible . Your inside inverter and common earths are all usually connected to this circuit.
What you do on a moving site I guess is get the best earth you can . Some boats connect through the sacrificial anodes but there are differing opinions on those. Some vehicles use a grounding strap hanging down from the chassis, some say the carbon in the tyres is enough to ground the vehicle . I don't think the Chinese know about ground yet?
It's stationary off grid . I have a generator power in breaker panel before the inverter and a breaker box for the power coming out of the inverter.We need to know exactly what your application is. Grounding a marine system vs stationary off-grid vs vehicle mounted, they are completely different. What type of system are you talking?
