Hello, I have a Growatt 3000 24v. When I first set up the system with batterys and ac in, I had ac out to my power strip.
Then today I finally had a chance to hook up a 200w 24v rich solar panel. The unit showed that it was charging via solar
giving me 36v. So then I turned on the power strip and nothing. So I put the power strip back together and plugged it
into the wall and it works! So the power strip is good. Im trying to figure out why I have no ac out. No codes and the one
breaker at the bottom of the unit is not tripped. Can anyone offer any ideas as to what might be happening? Settings or ???
Edit: I forgot to mention that I disconnected the solar panel to see if the ac out would start working, it did not.
Edit: I am running 4 SOK 12V 100ah Lithium batteries. 2S2P configuration
Thanks
Thanks
