Jmhai3
Built a cart system using the video and website as guidance and followed everything.
I had it setup with AC in and AC out hooked up, hand not a chance to hook up PV not even the wires.
- The AC in worked to charge the battery to full.
- The battery was setup to communicate with the inverter and was looking good.
- Ran a computer and small 400 watt heater from the power strip AC out.
- Pulled the AC in plug to test change over to battery without issue.
- Plugged back in AC in and it returned to bypass and charge battery.
- Tried to setup the Wi-Fi communication but had no luck. Which is common I see. Shut everything down.
- Next day tried to setup Wi-Fi again but no luck, waiting on the PV charge booster to show up since I don’t have enough solar input yet to direct connect. Still no luck on Wi-Fi. Unit was not hooked to AC in or anything pulling power from AC out while trying to get communication setup. No issues.
- Next day still no AC in or AC out being used but battery and inverter was on and trying some more testing of the Wi-Fi to get it working after reading some info online. While rereading the instructions the AIO unit just shutdown screen black. No beep, alarm, or indication something was not right.
- Shutoff switch on AIO unit, check breaker nothing out of place, shutoff battery, wait a minute turn battery back on startup fine and SOC full no alarm. Test battery out to unit 53.3 volts showing going in. Turn AIO back on and screen is showing no output and is blinking full screen everything lit up to alarm 6P to black screen and back to full screen and repeat.
- Plug AC in and it shows input but still no output and doing the beeping screen with 6P still.
- So this is the current process the unit is showing. Will add another post here for the first contact with SS.
