Having spent hours searching the web and many more hours trying to get this to work, I'm in need of help.
I've just had a failing SMA inverter replaced with a Growatt MIN 3600TL-X. It's working just fine. But I also have a ShineRFStick-X and LAN box whicj isn't working as expected.
The RF stick is connected to the inverter and has successfully paired with the LAN box. I can connect to the LAN box over my local network and login using the browser Admin.
The problem is the ShinePhone app shows the inverter as "Offline". The RF stick has been successfully registered in the app but whenever I login, it shows the plant as offline and reports "No Device".
I've emailed Growatt support but that doesn't get a response. I've also changed the server via the browser admin to server-us but that doesn't make any difference.
I'm in the UK and the installer doesn't want to know. Can anyone help?
