apctjb
- Jun 16, 2020
- 480
I don't know my Magnum 4024 takes 12 watts.
Point taken, I should have said not bad for inverters in this price range.
Depends on what your "36V" battery is for an actual voltage.Can these growwatts work with a 36v battery?
are you using 'eco mode' to talk about standby mode or power saving mode? can't find eco in the manual? i too would like to know when/if the growatt 3000TL LVM can operate at 2 watts and what it can do? i'd also like to know what is the power use while in standby mode or power saving mode and what i can do? from the manual i've found thisFor me, about 44w to 49w when not in eco mode.
Look at line #4 Power saving mode enable/disablare you using 'eco mode' to talk about standby mode or power saving mode? can't find eco in the manual? i too would like to know when/if the growatt 3000TL LVM can operate at 2 watts and what it can do? i'd also like to know what is the power use while in standby mode or power saving mode and what i can do? from the manual i've found this
*Standby mode: The inverter is not turned on yet but at this time, the inverter can charge battery without AC output.
*Power saving mode: If enabled, the output of inverter will be off when connected load is pretty low or not detected.
on the spec sheet is where it says Standby Power Consumption is 2 W
also note from the manual: Power saving function will be automatically disabled when in parallel operation.
thanks and can you verify that when in power saving mode [If enabled, the output of inverter will be off when connected load is pretty low or not detected.] the growatt 3000TL LVM operate at 2 watts and still charges the batteries from solar?Look at line #4 Power saving mode enable/disabl
I can not as I don;t have mine set that way. I just know the setting exists.thanks and can you verify that when in power saving mode [If enabled, the output of inverter will be off when connected load is pretty low or not detected.] the growatt 3000TL LVM operate at 2 watts and still charges the batteries from solar?
