I have the above Inverter and BMS and am wondering whether my inverter actually has CANBUS communication as I have been having some problems getting it to communicate with the BMS. I have also read that many others have the same issue and it turns out that some early versions of this Growatt inverter don't have the ability to communicate over CAN (albeit that it was advertised and sold as having CANBUS) and the coms must be RS485 between the BMS and inverter. The inverter was purchased in April and when I look at the manual it also references CANBUS.
There are two ports on the bottom of the inverter (one labelled BMS and the other RS485 - see attached poor picture). This problem would only be with the inverter as I am sure the BMS has CANBUS protocol.
Has anyone got this inverter with the same labelling on the port and if so is it supporting CANBUS? I have tried asking Growatt but the response is so slowwwww. Thxs.
