radurus
The increasing slope is more aggressive on the older FW. 40.05.A09 but the production dome is limited at the top because of 18A limitation.
I cannot figure out what caused the power drop at 10:00. I have to observe today it it happens because of the load.
If it happens again, there is no point to stay with the older fw and I will switch to the 2022 version (40.06) and take care about the load variation.
Based on the production numbers, it looks almost the same but it is not in perfect conditions.
Edit:
It seems the fw 40.05.A09 throttles down too in specific conditions.
I just tested having 4.3kw PV power and jump the load from 3.1 to 4.6kw.
The PV power dropped for few seconds to 3.6kw.
I will load the version 40.05.701 when I have time.
Last 30 days
Load | Solar PV | Battery charged | Battery discharged | Grid used | Grid exported | |
Oct 21 | 5.2 kWh | 9.0 kWh | 4.4 kWh | 1.9 kWh | 0 kWh | 0 kWh |
Oct 20 | 29.9 kWh | 29.6 kWh | 7.8 kWh | 10.2 kWh | 0 kWh | 0 kWh |
Oct 19 | 21.4 kWh | 26.9 kWh | 9.3 kWh | 5.1 kWh | 0.0 kWh | 0 kWh |
Oct 18 | 24.7 kWh | 30.0 kWh | 10.1 kWh | 6.4 kWh | 0 kWh | 0 kWh |
Oct 17 | 28.6 kWh | 30.4 kWh | 9.1 kWh | 9.2 kWh | 0 kWh | 0 kWh |
Oct 16 | 26.7 kWh | 30.9 kWh | 8.1 kWh | 5.7 kWh | 0 kWh | 0 kWh |
Oct 15 | 28.6 kWh | 30.9 kWh | 6.8 kWh | 5.8 kWh | 0 kWh | 0 kWh |
Edit:
