I have a Growatt DVM12000T with 8 Discover EVL16A-A 6V batteries in a 48V configuration. There is no solar input, as I am only using it for backup.
Over the weekend I experienced 3 outages. The first 2 were only relatively short but the 3rd was a bit longer, and I plugged in a generator when the batteries got low. My Victon smart shunt said it was 20 or 30% at the time, I think. When I have my generator on, I set the Growatt max charge current to 30A since any more causes the generator to stall when my well pump kicks in. I manually set it back to 80A once grid power is restore.
Normally after an outage, the Growatt charges the batteries for a few hours and goes back to float charging, but this time it appears to be doing something else. It looked like it went to 100% in a few hours, according to the Growatt and the smart shunt, but kept charging. The batteries got quite warm. It did start to taper off for a while, even apparently stopping for a minute, but then went back up again.
It's been going for nearly a day and a half which is way longer than I've ever seen it and I am getting worried about it. I have attached the charging power and voltage charts.
Does anybody else recognize this behaviour?
