zorrotm
Hi, I have purchased 32 440w bifacial Canadian Solar panels, which I will link below. I also purchased 2 EG4 6.5kw inverters, and 6 x EG4 Lifepower4 48v 100ah batteries server rack.
I intend to install the panels on the ground using the EG4 racks, positioning them approximately 150 feet away from the house where the inverters will be located. I'm relatively new to solar energy and have a few questions. Any guidance you can provide would be greatly appreciated.
Are the EG4 6500K inverters bad?
Firstly, I've come across several complaints in various forums regarding the EG4 6500k inverters malfunctioning and failing. Should I be concerned about the reliability of these inverters? Or am I being paranoid?
What gauge wire should I use?
Due to the distance involved, my plan is to connect the panels in series to keep the amperage low and allow for the use of smaller gauge wire. However, I'm uncertain about the appropriate wire gauge to use. I've used online calculators, but the results seem inconsistent and don't seem to account for the panels being connected in series instead of in parallel. I initially thought I needed 8 AWG wire, but Signature Solar said 10 AWG would have only 1% loss. Does that sound right? And should I use PV wire such as: https://www.wireandcableyourway.com/solar-photovoltaic-pv-wire
I am reading some say to get 7 stranded or 13 stranded wire. And what conduit would you recommend putting it in?
Does inputs in inverters need to be equal for each inverter and across multiple inverters?
My plan is to run 6 panels in series, which would require an additional inverter since each inverter has two inputs and I would need more than four inputs. However, this would result in an odd number of panels on one input, as 32 panels divided by 6 is not an even number. Is it acceptable to connect 6 panels in series to each input for two inverters, totaling 24 panels, and then use the third inverter to connect 4 panels in series to each input, for a total of 8 panels? Or will this imbalance something?
My original goal was to run 8 panels in series per input so the two inverters would handle all 32 panels but I am being told by other people with solar that the inverters won't handle all the power the panels will produce?? I guess if the bifacial was to produce well maybe this is possible idk. Two EG4 inverters would offer 16kw input. 32 x 440w panels is 14kw. If bifacial was producing 20% then it would equal 16.896kw but this seems unlikely as I am in Upstate New York. Thank you for any help
Solar Panels stats: https://www.canadiansolar.com/wp-co...dian_Solar-Datasheet-BiHiKu_CS3W-MB-AG_EN.pdf
