mytoolman
- Apr 2, 2020
- 36
I need to produce 1000 Watt per hour of solar power. For simplicity lets just say its for an RV. Its actually a tool truck but they function the same for electrical use. I have six 6volt 225 ah float golf cart batteries set up to produce 12 volts. Im not sure if they are in series or parallel...I am confused on this my photo shows the battery bank. These batteries are 4 years old and have NOT been taken care of. Twice in 4 years they have been found to need water. I used more than a gallon of distilled water to top them off twice now. 4 or five times I have found the low battery buzzer alarm on. They have been charged too fast etc....meanwhile they are still functioning and I need to keep using them until I cant. My eventual goal is to go 24 volt.
I want to go Flexible Panels. I need to be careful not to spend the money more than once so I will bite the bullet and buy quality and spend more initially
since I in the next 2 years will probably have to buy batteries and want to go 24 volt what specs do I need to look for to buy good flexible panels?.. what specs do I need for a BMS that will work what I have for batteries NOW and Later when I have the 24 volt bank?
Is there a place to shop for all of this once I know what to shop for other than EBay?
Also is it possible to get 24 volts NOW? is my thinking wrong that if I add TWO more 6 volt batteries and have them connected properly I could have that happen? I want to limit the gauge of wire I will use etc if I can NOW and going 24 volt will do that right? I wish I could just trash my batteries and buy LiFePO4 batteries right now...I would have been on my way already well maybe not actually...I still dont know what panels to buy for them either..
