GoetzSaCebu
- Jan 7, 2022
- 57
Ok 1st thing I live in the philippines and sunrise here is 6am and sunset 6pm (to make it easier).
I installed my system 8x 500W panels now facing sunrise and I see that from 7am it already generates 0.5KWh until 3pm when the roof is in the shade and production drops.
What I want to change is that 4 panels face sunrise and 4 panels face sunset - so that I get more power even in the hotter afternoon!
But my installer tells me that its a bad idea, because the lower generation of the panels facing the shadow side will lower overall power that the inverter will generate (DEYE 5KW hybrid with 2 seperate PV inputs).
I asked DEYE and their answer was:
"Hello, your idea is right, 1.5 kw + 0.4 kw = 1.9 kw, but I suggest that solar panels should be mounted on the strongest side of the sun so that the energy output is maximized."
Somaybe someone here can answer me this:
Given 4 panels facing sunrise - generating 2KWh and 4 panels facing sunset generating 0,5KWh only.
I should still get 2,5KWh usable poewer, and not only maybe 1KWh because the inverter somehow limits what he can use by the input from the weaker channel.
And NO I wont install a suntracker system because my roofs are already pointing in the directions I need.
As my installer still thinks its no good idea to what I think of I now want to know from your experience if (especially DEYE inverters) maybe have a stranger behaviour than what I would say are regular inverters that would just add up the power they get.
