I need help diagnosing my system.
It doesn't seem to be putting out the power it should.
System is as follows:
-2,600W solar array ( 8 panels each are 325w-10a-40v panels)
-Renogy Rover 100A MPPT Charge controller
- 12v 600ah lithium battery bank
- renogy 2000W inverter
Wiring is good, oversized slightly. There is almost no loss of power at the charge controller in relation to what is put out at the panels.
My average output for the entire array is about 300w/hour measured at the panels.
This seems way low.
When tested at the panels, they are producing the correct amount of volts but their amps seem low. They only put out 2 or 3 amps per panel and 4 to 6 for the entire array. I have 4 sets of 2 panels (series) wired in parallel. Sorry, I don't know how to better say that.
My orientation and angle is good, there are no obstructions it gets full sun all day.
I have had times where I get 600 to 1200 w generating in the mornings when it is cool.
However that does not last for more than about 40 minutes. The panels heat up significantly and the output drops.
Is it realistic to only be getting 15% or rated output?
I would expect more like 50 to 70%.
I would love any help or trouble shooting tips you guys can give me. I'm happy to send pictures as well.
This seems way low.
