Not that I'm aware of? Speaking of indicated room temp BTW...since the sensor is integral with the indoor unit - and I assume this to be true of any mini split - it's influenced by indoor discharge temp, so seems to be programmed with overshoot ( or you could setup the sensor with a false or "expected" offset just as well, but Deye seems to have chosen the "true" temp approach..)
Example. Set Heat to 80. It will run to 84 or such on its indicated room temp in the app, since due to the local proximity of discharge to sensor this would presumably result in a actual room temp of 80 (?)
Vice versa for Cool...set temp 66 may show sensed temp 62..
Making any sense??
If anybody has more knowledge on this let me hear your thoughts. There has been a lot of general mini split discussion on the board lately
